"liquid" sounding clunk shortly after start up
Possibly, all I know is that it is the ABS pump, which is cycling brake fluid.
ah yes, I think you're on to something! Is the ABS pump the device on the passenger side that has a number of hard lines coming out of the top?
Yeah, its the ABS pump doing a test cycle/pump. Normal, don't worry about it.
It actually makes the sound a few seconds after you remove your foot from the brakes. For me, the sound comes after I have backed out of the driveway (a bit downhill, so brakes are on) and shift into drive on the way down the street.
-Charlie
-Charlie
cool, I'm gonna do some testing when I get home but I'm about 90% certain this is what it is. thanks everybody!
-Charlie
Exactly how it cycles on my 1998. My guess is that it is the same cycling routine for 98-00.
My 2000 4R and our 01 Camry do the brake check as others have said. As yours makes that sound, if it is the brake check, you should also feel a faint pulse or vibration in the brake pedal with the sound. In both of our Toyotas they do it as in the first 15 feet or so as we're backing out of the driveway and I feel the brake check in the pedal since my foot is applying slight pressure on the pedal.
