List of Customizations That The Dealer Can Program for 2010 T4R
Are you guys getting the dealer to program these options for free or coinciding it with an oil change etc? I will palm the tech an Andrew Jackson if he can make my remote lower the windows. Only wish remote start addition was this simple...
Most dealerships will give you a free programming one time. After that it's usually 50-75 bucks.
Remote start programming took them a couple of hours and they won't do that for free unless you make it part of the original deal.
Remote start involves installation of a module or receiver though correct? I got a quote for $600 and that's from the dealership I purchased. Unfortunately they are 2 hours away so getting the programming done may cost a few bucks. I don't mind and don't feel like waiting until the 10k mile mark. that may be year away. Going to do an oil change much sooner than that.
Thanks for the info everyone.
I had remote start added in as part of the purchase, and they had to order a module (I think). Once the part arrives, it will be programmed in for me.
And yes, it was about $600. :crybaby:
Can someone explain some things to me? I got a bit confused.
With the custom settings can you auto roll down the windows other than the back window? And, can you use the remote to roll up the back window now?
Thanks,
Rob
The pdf file in the first post shows you all the things that they can do.
They did it for free for me when I took it in to get the Remote Start installed (and to correct some other issues during delivery).
Um, thanks I think. Like I said I was a bit confused and was asking for some clarity regarding what was possible. Chock it up to me being a bit slow.
You can use your key to put up the rear window by turning it to the left and holding it there for a second.
to clarify: You can roll down the front and back windows and sunroof remotely with the key once the setting is enabled. The hatch window can't be controlled remotely. Once open you would have to turn the ignition on or put the key into the drivers door to close the windows. The hatch window works with a key (SR5 and Trail) or the buttons (Limited) on the back.
Hope that's clear...
Thanks,
Rob
I have a 2011 LTD and can't figure out how to get all the windows back up with the remote once I lower them with the remote. Does anyone know? Thanks!
You can't. The remote only rolls the windows down, it will not roll them up. That's by design. You can, however, use the arrows on the back to roll the window up manually (rear window) with limited's smartkey system. (Which is the same one I have)
UPDATE:
Technician came out with his computer system today and went through each feature step-by-step to ensure I knew what features he did and which ones he couldn't do. Here was what I had changed (for free btw):
- Windows roll down with SmartKey (roll up feature showed "not available")
- Opening moon roof wirelessly (it slides open completely)
**** Rear window does NOT roll down when the windows and sunroof roll down/open****
- Had doors lock feature changed so when vehicle is shifted into Park it does NOT automatically unlock the doors (moving to San Diego (close to Mexico) and don't need to get car jacked.
- Driver/Passenger Seatbelt Chime Disabled (I can't tell you how nice this feature is to have removed)
- Rear Wiper Interval Speed changed from 3 seconds to 5 seconds (Nice for wet road days)
- Opening Drivers Door Handle Sensor unlocks all doors
guys, is there a document that shows that this procedure is supposed to be free?
the moron I spoke with today, went from "no you can't do that" to "it'll be 219$" within 30 minutes..
I want to show to his manager the doc..
guys, is there a document ...
don't know if there is a document per se, but when I had everything changed I just told them ahead of time when I was getting oil/tire rotation.
if they won't do it for nothing, find another dealer that will.
that's the thing. Spoke with 3 dealers, and they asked me to speak with the dealership where I bought the car from.
I'm going to talk to the owner tomorrow (I do work for this dealership periodically), so we'll see whats up.
When is someone going to hack up a freeware pgm to change these settings with a laptop...or better yet a smartphone via usb or bluetooth:moping:
If I missed it in the manual, sorry, but can you run the fog lights without the headlights on? I'm pretty sure I tried all combinations with the light switches, but can't seem to get them on, by themselves.
REE
