Living on the edge
Thanks for sharing. Hopefully the lessons learned through this discussion will prevent someone else from having a similar (or worse) experience.
Something else to keep in mind with jack stands is that they are typically rated as a pair. This means that a pair of 3 ton stands can support 3 tons when distributed equally over both stands and that a single stand is only good for half the load rating; in this case 1.5 tons. 4Runners aren't light vehicles, and 3 ton stands are cutting it a bit close for my liking (example of why). My preference when working on an SUV or truck is to use a pair of 6 ton stands per end. The extra load rating is peace of mind knowing that a single stand should be able to hold up half the truck if necessary, but the significantly larger base size used on the 6 ton stands provides much needed additional stability as well.
Having dropped a car off a jack once (totally my fault, thankfully no one was underneath anything) I don't mess around with safety anymore.
Agreed, 6 ton for trucks. Not just for the capacity but for the size, height and stability.
I had my 4 runner slide off partially once while trying to find a noise by cycling the suspension on one side up front. I only had one wheel off, but it quickly creates a domino effect.... Nothing to mess around with.
Good to know. I was not aware of that. But, I've never used just one stand, always two, and will continue that now that I know this. I'll probably get two more 6 ton stands then and save the smaller ones for lighter vehicles.
See [MENTION=120209]tigger[/MENTION]; I now know more than before and will be safer because of this thread. Thanks.
I think the bracket smacking you in the head was divine intervention trying to get you to pay attention to what you were doing. smack.gif Glad nothing bad happened!
My stands are 6x6 wood posts 3 1/2 feet long with a tapered ramp cut into each of them. I drive the truck up onto four of them. Nothing moves.
Me too. Attached a 2X8 under each of the four 6X6 ramps for even more space under the rig. Simple and real safe.
