llast tire question i have, about to pull the trigger
Yes it appears that they are according to this LT265/75R16D1 119Q B
I believe the D after the R16 is the identifier. I always get so confused because you can find one that's D load but has a different speed rating or treadwear etc. I guess it's good to have all those options.
cool thanks guys
is there much difference between 245-75-16 and 265-75-16 besides the tread width?
I understand the 245 is a bit narrower, but is that it?
Yeah a 265 is close to 1.5" taller. Check this link out Tire Size Calculator - tire & wheel plus sizing
Just input the two sizes and you can see the difference.
That is strange, cause 245's seem an odd size, you dont see them often.
but I can get a set for $200 with only 4k on them. and might get them to just run them till I can get what I want later down the road.
but 1.5 is quit a bit when your going down adn not UP .lol
Yeah my girlfriend has 245's on her Jeep GC and my stock 95 wuth 31's sits much higher. They don't look bad, but I wouldn't run them if you are going to lift at all or have flares.
By the way- Nitto Terra Grapplers are on backstock. Discount doesn't know how long they'll be that way but they told me it's been a while since they've had them. I wouldn't place the order if you need the soon... Could be a long time they told me!! That's why I decided against them and got other tires
(if you look on the right of the page by add to cart it says backorder)
by the way- nitto terra grapplers are on backstock. Discount doesn't know how long they'll be that way but they told me it's been a while since they've had them. I wouldn't place the order if you need the soon... Could be a long time they told me!! That's why i decided against them and got other tires
FYI. Kelly safari tsr's from onlinetires are 644 delivered (to me). I've read some not so positive things about onlinetires so maybe take a chance or find someone to match. Good luck
Just trying to help a brother out... Looks like your on the search for some other tires
well i definitely stretched the budget but i just sucked it up and called them and told them to switch me to duratracs. sigh. 785 shipped with the warranty :sobbing:
DJNutshell
