Pikeman
Ok here is a simple run down
Aussie, Loc-Rite, Spartan all nice affordable lunch box lockers, full time
Detroit- very strong, full time but need to reset your gears since you are replacing the carrier
E-Locker- nice but will have to mod your axle housing to retrofit. Expensive but good and also selectable( can turn on and off) Inchworm 4.88 $1524 ECGS only sells without motor $620 plus motor($$$$). Then you will still have to wire($120) and modify housing labor involved cutting grinding welding.
ARB- selectable like the E-locker requires a compressor and also resetting gears like the detroit. built 3rd ECGS 4.88 ARB $1435, Inchworm 4.88 $1230 need compressor($250) and can more than likely install and plumb yourself.
End up being about the same price with the E-locker(unless already equipped in which we wouldnt be asking what locker to get) being slightly more expensive. Plus if you spend $400 on the air source you can get the VIAR 100% duty cycle compressor with a 2.5 gallon tank. This will give you the air to run lockers and also air tools and fill tires. Even if you go with basic ARB compressor you can still air up your tires.
