Looking at an '88, & have some noob questions
seely
I found a pretty clean '88 SR5 with a newer rebuilt engine at a decent price locally and went to check it out. It all seems mechanically solid, the engine pulls very strong, but the auto trans seemed to "hunt" a bit. I'm not familiar with 4runners (previously owned 1st gen Monteros), but they do share a trans, more or less, in theory.
I got the truck up to highway speeds no problem, but it seemed when I hit 4th that there was almost another shift afterward. I'm assuming this is O/D, but I've never noticed such a pronounced O/D shift before.
Also, at lower speeds, the trans seemed to "hunt" up and down a bit even with my foot steady on the gas, on slight to moderate inclines. It didn't seem to slip, and it shifted smoothly. Just seemed to shift more than I expected.
I'm used to something with a bit more displacement, so I am willing to concede it could be due to the smaller power plant, but just want to be sure this is relatively normal for a 4runner auto trans.
Appreciate a heads up on any other advice you'd have to someone looking at a 1st gen 22RE with an auto. Thanks!
The engine is reliable, but it is a 80's 4 cyl that would be considered under powered in today's vehicles.
I would imagine it was the transmission was working harder to keep the rpm's at a good band. To give you an idea, just how under powered it is, compared to today:
According to the specs: the 22re came in 2 versions, that either put out 78 or 84 HP at 4600-4800 rpm.
That is why a manual would be preferable in it; as you have much more control. Just to compare, my 1988 Subaru station wagon put out about that much and it struggled on the freeway!
EDIT: Do not kill me for this, it is a great engine; I was simply trying to explain WHY at high speeds his transmission might be hunting up and down hills!
I figured as much, it was just odd as it didn't seem like the truck was bogging or struggling at any point; it was almost like the trans was shifting early or a little too eagerly. Regardless, it was smooth and performance was pretty good up to about 70-75 mph.
I have the same underpowered 22RE the OP does, and it doesn't hunt like that. It does downshift right away when I'm flat out and hit a hill or a headwind... the 22RE doesn't mind WOT at all, but even with my aftermarket cam there's not a lot of torque up there for it to play with either.
By the way, DC, spec on a late 22re is 112 HP. Not a huge difference, but we'll take all we can get. :)
The guy selling this figures about 140hp. He got a header for it, and did an oversized pipe, no catalytic converter, with a freshly rebuilt head and a remanufactured lower. I was surprised how well it moved with the automatic (especially once past 1st gear), so maybe he isn't too far off.
So dyno it. If you're making over 140 I'll go back and read your build thread again. :D
What does a dyno run normally cost, anyway?
I'm not sure what a dyno costs, but I'm not really interested in doing it. If I built a race car I would. All I wanted was enough power for my 4runner to get out of its own way.
All I can tell you is that I'm running 35's on steel wheels, 5in lift and stock 4.10 gears and my 4runner does pretty well.
FWIW: For what I spent building my motor, I could have done a 3.4 swap and had a lot more power.
I drive a 84 Xtra Cab 2WD that has a 22R and the automatic, I noticed it does want it's revs to be higher when around any type of hills. The truck only has 120,000 miles on it so I am confident it is working correctly. And when it hits O/D you can definetly feel it, it kicks in at no slower the 52 mph, and drives great so I wouldn't be too concerned, and when the trans is cold, it shifts harder also.
RangerJay904
