Looking for CarPlay headunits
Timjtitus
I’m looking to replace my failing factory radio with a CarPlay unit. I’m concerned with how low the radio is and if using Apple or google maps would be a PIA to use. Any recommendations?
I went with the Pioneer AVH-1300NEX. I would definitely prefer the unit sit higher, but I've gotten used to it. Glare hasn't been an issue. I'm not sure if the tilt helps that much for easy viewability, as you still have to look down.
I'm currently looking into new head units as my current nav unit is starting to act up. The CarPlay idea is looking nice for me.
Right now I'm looking at the Pioneer AVH-W4400NEX and the Pioneer AVH-2400NEX. Not sure if the extra price of the 4400 is worth it. Would love to hear if anyone has any thoughts or any other head unit suggestions.
I put a 7" double din Kenwood in my 2000 4runner. Has Appleplay and Im nuts about it. No problem using maps from my iphone. Reads text messages to me, makes calls from voice commands etc. Sort of wish it had an old fashion volume knob instead of the up/down volume buttons but I got used to it. Bought it from Crutchfield along with their wire harness. I was able to put it in myself. Not too hard if you follow videos on youtube that tell you how to take off the center consol. Has capability for a backup camera if you want to add one. Also can play dvds but I didn't wire it for that. I chose the Kenwood over other brands after researching.
I have the Alpine ILX-107. It's wireless and I love it. Just leave the phone in my pocket and it automatically connects. It's a little expensive (or at least was when I got it a couple years ago) but worth it for me. And it works fine in the stock radio position even being so low in the dash. No issues with viewing angle or anything. Only downside like someone said earlier is no physical volume knob, just touchscreen buttons. A little weird to get used to at first
I have the avh-4201nex, wanted one that came with the backup camera. My buddy has the w4400nex and the're pretty similar. I'd only recommend paying for the w4400nex if you want a Bluetooth connection to carplay or Android auto. I actually prefer wiring in as I Bluetooth over to my obd2 reader and have torque pro. I believe the 2400 is the newer gen so if you don't care for the wireless car play and want to save a little cash I'd say grab that.
I just picked up a Sony XAV-AX100. Super happy with it coming from my old Kenwood. The screen responsiveness is quite good despite it being a resistive display. It's more sensitive/quick to respond to touch than my mom's 2016 Touareg TDI R-Line OEM unit (and VW's typically have pretty good displays - FWIW). Bonus for the Sony's "OEM +" looking aesthetics too.
Thanks for the intel. I ended up going with the 8200nex. Been super happy with it so far.
How is the head unit holding up? Anything else needed besides the head unit to install it? I’m digging that simple design
I have the same one and I can't say I've been wildly impressed. This was the first wireless carplay available, and it is not set up to get firmware updates, so what you have when you buy it is all it will ever have. I have the odd issue with it freezing or failing to connect, not often but enough to be annoying. The other issue, as you said, is the touchscreen volume control. I did a lot of research trying to figure out a way of doing remote volume control and couldn't figure anything out so I finally gave up on it. Some of the newer wireless carplay units seem both cheaper and better.
I have the ax100 as well and love the simplicity and oem look. It’s a bit small, but it has one thing almost entirely unheard of these days...a volume knob! It was very easy to install, fits perfectly with no extra brackets or fiddling. Just use the usual Toyota harness kit for clean wiring.
The unit works great and has been holding up since I put it in 3 years ago. They’re phasing out that model but you can find it at Walmart online and occasionally in store or used on eBay for cheap.
That said, it has its issues. Software can be buggy, it boots up slow and is generally sluggish. If you press the button for rear cam it’ll just stay on until you power cycle it. You just learn not to do that. Lol. It also has an incredibly annoying warning screen at boot that stays on way too long. The newer firmware reduces the timeout but a hacked older firmware has it entirely removed (that’s what I use).
The ax1000 is newer and snappier and has more convenient usb/aux, but takes away dedicated track buttons and android auto for some reason.
The ax5000 is the newer variant with dual CarPlay/android auto, is super snappy, but goes to a bottom row of buttons that sticks out instead of ol’ knobby on the side(and flush!). Put this one in the GFs CR-V bc I got a deal on an open box (don’t tell her). I much prefer the look of the old ax100 in the Runner.
I looked at that model too as wireless CarPlay really needs to be here in 2019/2020. I shyed away because I was afraid of exactly what you described. Ho hum, cables forever I guess.
Well don't let me scare you off it, there are some good sides to it to- screen looks good and is responsive and snappy. If the wireless side doesn't work you can always plug in to USB and it will work that way. I'd say it glitches on me around every 2-3 months.
One more thing, don't get this unless you intend only use it as a carplay device. Without a phone attached you have a very basic radio function only.
All the more reason to love my Scion head unit. 300 watts Bluetooth etc. then I put a 2013 NAV unit in.
Thanks for clearing all that up. Is it less convenient now that they took away the track buttons on the ax1000? I’m guessing the buttons are now on the screen? Also what’s the Toyota harness? Where can I get that?
Yeah, they would be on screen. Not really a big deal. Having the aux and usb on the front is probably a lot more convenient too but I feel having them on the back on the ax100 makes for a cleaner look. The harness is just the usual aftermarket wiring connector so you don’t have to cut the factory plugs. Metra 70-1761 for our cars I believe.
Philthyphilthy
