looking to do auto to many trans
Red2ndgen
in 1990 toyota 4runner 4wd kinda poking at you can do it lol but im stating to collect parts picked up trans with xfer case for 200 bucks pedals and hard lines at pick a crap not really worried about install other than elec stuff been looking for a good install thread just couldnt find anything does anyone know of a good thread write up thanks a mil
when i start it im going to do a write up for sure step by step i know i will find the :redbrick: with the :roadkill: but it will be worth :sobbing: over when its done and i going to take care of some leaks why im at it
it hardly seems worth it to me with all the ECU swap and harness swap and doing the pedal carrier swap and punching the hole for the slave cylinder it just seems like at that amount of work you would be better of doing a 3.4 with a auto behind it.
this is the parts I have so far.
trans
clutch kit
pilot bearing
throwout bearing
slave and master
flywheel
hard lines and soft line
pedal assembly
new flywheel bolts new trans mount
and hard wear
havent seen anyone have any luck with a 3.4 swap with auto work right. maybe i missed something. which auto trans would you use
DexterShaYang
