Loose Shifter? - Replace your shifter bushings! - Write up with pictures
ramonortiz55
My 4runner's shifter had too much slack for my liking. I was worried that one day I wouldn't be able to turn on the 4runner or have it release my key from the ignition. So I decided to change the shifter bushings as preventative maintenance.
This writeup also applies for 1st generation tacomas.
Each shifter assembly requires four bushings, here is the part number:
full
Stare at the center console for 5 minutes. Give it a long mean mug stare.
full
Set hand brake and grab pull out the cup holder:
full
full
Next pull out the trim around the shifter, simply tug:
full
Remove the center console. This is held down by two bolts inside the console:
full
Remove the screw holding the center console to the shifter trim, one each side. This will allow the center console assembly to pull out of the way:
full
Next remove the 4x4 shifter head, my particular setup is not threaded. Therefore, I remove the set screw and pull the head off carefully.
full
Be very careful not to pull the wiring that leads to the 4x4 shifter (black).
full
I placed it to the side, did not really disconnect the wiring because I was afraid of messing up the pigtail connection.
full
Next I removed three screws that hold the shifter down to the assembly:
full
Once removed, it revealed this white device thing:
full
full
I removed the three screws that held it down. Pay attention to how it is mounted, there is a rectangular piece that goes inside of it. This needs to properly seat within a slot that is built into this device thing:
full
Before continuing, I went under the truck - Driver's side, and I disconnected the shifter from the transmission. Making sure to mark the location where it is bolted along the slot:
full
full
full
Once that is complete, I went back up to the shifter assembly and removed 8 of these bolts. They are located on the perimeter of the shifter panel against the floorboard:
full
Disconnected a couple of plugs to allow removal of bolts:
full
Had to pull the radio bezel off the dash to access one of the bolts:
full
Pull away! - here you can see the location of all 8 bolt holes, for reference.
full
Now that the shifter assembly is out, stare at it. Show it some attention. Give it love.
See this nut? Remove it.
full
It will release this bolt:
full
The shifter bushings go in each end of the bolt housing:
full
Old shifter bushings, rotted away:
full
Make sure to clean out any remaining bushing pieces within the bolt housing:
full
Install bushings and install bolt.
full
Next, I located the other two bushings, these are in here:
full
full
Remove nut and bolt, just like previously done:
full
Once the nut and bolt is out, you will need to break the linkage as shown here. This is done by removing a C clip.
full
full
Once the linkage is apart, I wiggled the housing up so I can pull out the old bushings:
full
Installed the new ones:
full
Install bolt and nut, reinstall linkage and C clip.
full
Reinstall into truck:
full
Reattach rod to transmission:
full
Carefully assemble the white thinga-machig to the shifter. Make sure that the rectangular portion shown in the photo earlier lays within the channel:
full
See this? - How does it go?
full
Let's find out:
It directly connected to the emergency shifter release button:
full
Looks like it toggles when I move the button back and forth, two positions:
full
full
Looking down into the shifter assembly I see this triangular piece of plastic. Lets set it BEHIND this piece.
full
Once it is set, I check for functionality:
full
See that white plastic cylinder? Its right above the screwdriver tip. Toggle the release button, this white cylinder should move in and out, if installed properly.
full
Once you confirm functionality, reinstall everything else:
full
How is the shifter?
Mine is tighter than a frog's arse![/COLOR][/FONT]
new gromments
Great pictures and description. I was super careful with that white plastic piece, i can imagine it breaking without due diligence. People says it a easy job, but i thought i was nerve wracking.
This is really, really good timing. I picked up a set of shifter bushings two days ago and plan to replace them this weekend.
[MENTION=122940]ramonortiz55[/MENTION] thanks so much for the write-up. It made the whole process SO much easier. It took me about two hours but I used the opportunity to do a lot of cleaning too.
My shifter no longer had bushings in it haha. It's much, much tighter now. Still rusty though. A decade of salt air and beach sand will do that I guess.
I ve had the shifter bushings but just haven't got around to it yet but with your great writeup with pics I am sure I will shortly. Thanks
Great job on the photos, I replaced mine yesterday also. I did put some white lithium grease in the new bushings, and I replaced the grommets and brass bushings on the bottom side linkage. I should have also ordered a replacement link on the top side that is held in with the E clips. It has a little bit of wear in it. But overall it makes a huge difference in the feel of the shifter lever.
Nice write up!
Where did you get your accessory switches under your radio?
Do you have a write up on installing them?
I did the top two only, and did not have to tear it down as much. Shifter day and night on side to side play, also improved front to back too.
Thanks for posting this useful writeup. Knocked this out in ~30 min last evening. The difference is amazing, a shifter that does not bounce around like crazy results in more relaxed driving!
I did run into one surprise....the shifter boot between the gear selector and the tranny was torn....quite extensively. So I ordered part #33555-04040 and will have to tear into it again. I would recommend for anyone doing this job to go ahead and buy that $6 boot in case yours is torn too!
GN-gAeDaMwoBzRkt6bRbSQWd7uG3RSrBc83fevfay-bAtZT7l9l3GEQ2o7zScw9hr2A8xRx-QNL9voxv3oM0WqXKcq6N1ckPUs7UoFyYiI4hScl901BAW58ogcJmKk7jf56uZ-B2Qbe2tKmfRUux5vcCR2ftAoWvAHKIZCUZlawJ0W7UWlYhkTvTZNWDHJnKZOvwUAxJ38t6Mx6Kxuxdg_7eZZkhf_9feeWi63gHHNshgAEbf8gsUmXPaSXGMq-xfiw-4vn4aNn55DnrX-OjtYuWkx1InDsR4n7AzL1BLx0NuRNLilDhnHFwsmdMirht8YSmiGQ1b3mFGP0lfidOt-sFy09uVSjdOM1kcCjZOLrO_KJPVJPkDuM2puKUo33XeEBrygNGWMkQk7wi1Syx7Quf54m5b6JuKueET2VHbANK3H3KNyTN2UNJ_wMfiRaN7ZgUahp-s0xEYQR2DgnuyL3EglyKhfL0e5HpihlVVh3Zu4mUC5QKIBFHNnF7JCSME4F2ukyTtxOeYLfA_uynMmD8mPSjpIvu_Hp9jbpn1u3ag5kmIxAghpyII8OGPkJVSxnu8wKCF6BSZJ-7Jzpx47kgwSsfkAG1ToKm2gpWvuoE5sH2OFmeSXUcW6lvmM5BiF_DTBH8W4Zsmo3fIWK-_AsV=w835-h626-no
Please note, the part number I referenced above for shifter boot was not correct. I'll continue to look for the correct part # and will update when I find it.
Philthyphilthy
