lots of parts for sale!!! (roof rack, engine parts, etc...)
there is a white tag on the back of the rear cargo mat, should tell you a part number and what version its for, that way you can let the rest of us know ;)
not that i need one, already found one for my third row girl.
the engine wiring and the complete ECU stuff.... are those two separate harnesses or does the engine wiring come with the ECU wiring? If they are not part of the same puzzle... what exactly does the engine wiring connect to? And the ECU wiring...does that web of wires go to all the different ECUs (trans case ecu, engine ecu, a/c ecu? Thanks!
Do the 520s come with the switches, wiring, and associated hardware? Interested in the Ion Crystals
the only thing that is missing is a switch, the piaa switches were crappy and failed right away but I have the harness and relay and all the wiring
That web of wiring is the ecu harness and that connects to everything including the tranny engines ecu injectors all that, the other harness is the alternator harness that connects to the battery terminal and alternator
BUMP BUMP BUMP!!!!
with updated inventory
sorry i was bad at getting shipping rates last time, ill get on it this time
There are two harnesses, the ecu harness is the complete harness, the smaller harness is the alternator engine harness
