Loud banging noise post lift.
Miyota
Hello guys,
I am the proud owner of a 2000 limited third gen that just turned 200,000 miles. It is my first 3rd gen 4runner but I have owned and lifted 2 different 2nd gen 4runners. My issue that I am having is in my front end after my lift. Just so you know I am 99% sure this truck has never had ball joints or tie rods replaced. They look to be original. So I order and installed from toytec 5100 billy's both front and rear. Up front I have the toytec/eibach spring on the second perch and out back I went with super flex springs. I had my mechanic put the strut together for me so I didn't have to. He was only able to use the bigger of the two bushing that come in the kit when he put it together. Now after everything is in I get a loud banging noise but only on my passenger side and only when I hit a good size bump. I also am getting some strange vibrations out of my front end from time to time. My question is should I be looking not at the strut but my cv axels? The one on the passenger side is bleeding out grease pretty good since the change in angle. Or do I need to make an adjustment to my struts? Any help would be great. If you want some pictures I can get some for you.
did you have a front end alignment done post lift?
sounds like something could be binding. Throw it up on some jack stands and inspect for missing/binding parts
I thought i heard on another thread that some had issues with the super flex springs 'slapping' when going over bumps fast. Does it sound like it is coming from the front or the rear?
seltzernator
