Low Beams not working.
JPR Ram
I'm in need of help. My low beams are not working. Hi-Beams work. I noticed that the Hi-beam indicator on the dash is always on. I changed the headlight relay under the hood. Any advice as to what to check?
1999 Limited 4x4
1999 Limited 4x4
Can you give us a bit more background? Is this 4Runner new to you, or have you had it for a while? Is this a new problem? Did you do any work before the problem appeared?
1999 Limited 4x4
Check the fuses.
I assume you must have checked the fuses. I had both bulbs out once. I figured one must have been out and I didn't notice.
If not that then you need to check for voltage at the bulb connectors and start working your way back.
thadjay
