Low idle speed on V6
freeflight
Hi there,
Just noticed the idle speed on my 04 V6 is 500rpm. The truck has been driven over 20 minutes and fully warmed up. Ambient temperature is about 50F. Haven't done anything to the truck except coolant and oil change. I remember it used to idle at 600rpm or even more. Any suggestion on how to fix this problem?
Just don' want it to stall at a stop sign.
Thanks,
Kevin
yea my battery recently died and i had to jump it a few times... it would do the low idle speed and even die at stops... i just got a new battery and then had to dissconnect it once after installing it... now its back to normal.
Toyotas are weird. Once a battery goes flat or is replaced it completely resets the computer. And you have to drive it for it to relearn everything. Background info.
I'd go get the battery checked, if it comes back as ok. Disconnect it and go from there.
Thanks. Will get the battery tested after work today
AndiGarage
