Low tire pressure light is flashing
doozle007
I have a 2004 Toyota 4 Runner SR5. I switched out the wheels for the OEM 18" wheels off a Limited. The tire pressure light, "!" is flashing. I'm assuming because the Limited electronics are a little different then that of the SR5.
Does anybody have any ideas on getting that light to turn off??
im assuming that you switched the TPMS monitors over from your other wheels?
if you didnt most of the time when TPMS lites flash is either its got a bad monitor or there not programmed. so either bring it to the dealer to register the sensors or find a shop that can. personally i got one of these in my toolbox at work and its friggin awesome. TPMS Tools - Tire Pressure Monitoring Systems
good luck
you still have your old wheels? if so, put them in the garage or somewhere near where you park at night & the light should reset to off. it will go on again after 1+ hrs. or 100 miles driven.
ZukeMan26
