Lower ball joint nut
Stiles97
Should the lower ball joint nut only be finger tight after cotter key removal? Guess maybe I should count my blessings or is this normal? Anyway, power steering rack bushings installed already , lower ball joints and outer tie rods in the works.
Matt
I think he was afraid his ball joints were going to fail due to being loose. Although I think the cotter pin pretty much eliminates the possibility of the nut backing itself off though.
If not tq'ed correctly the nut and threaded portion can sheer off. Both from under or over tq.
Well, new oem ball joints are now installed. Properly torqued. Good for another 200k ( ok maybe 100k ).
Thanks for the input ,
Matt
