Lower Control Arm Replacements?
I'm glad I didn't go that way with mine.
I pulled some off a 2008 4runner with 40k on them at the auto yard near Mt. Rainier last weekend. They looked great and the balljoints were solid; removed from the donner with hand tools.
They worked really well this weekend on all the washed out roads on the North Side of Mt. Adams. I had the whole mountain to myself except for a few PCT'er, who I envied.
I replaced my stock LCA with the Mevotech Supremes. I was happy with them at first, but after only 6,000 miles I think the bushings are already shot. I'm getting that same popping/thunking sound from the LCA area.
Not sure what I plan on doing now.
My mevotech supreme LCA's are still holding up decent with about 5k miles, a lot more highway that you probably though. No bad sounds but not feeling as tight as new. I wonder if the aftermarket arms will accept poly bushings? I'm thinking this is the only other option to get me the feel I'm after without breaking the bank.
I've had the 1AAuto LCA's on my 05 for at least 15k and my wife's 04 for around 5k. Both are holding up just fine, felt solid during inspection and installation, and appeared identical to OEM, minus the 10 years of rust obviously. I used aftermarket cam bolts on both vehicles and greased them up plenty prior to install.
The price for these LCAs can't be beat. $160 for BOTH, wow!! I might have to get a set since mine are OEM and at 320xxx miles. Still no issues with OEM but figured when I do the 6112s up front, I might as well change the LCAs at the same time.
Moog LBJ on OEM LCA?
I'm trying to figure out what I should do and what people say about the Moog LBJs?
I just put a lift on my 4runner and when I went to get it alligned, the LCA bushings were shot. I needed the truck back quickly so we decided to replace the bushings. Then we noticed the CV axle boot was leaking grease so we replaced both CV axles, then one of the cam bolts was seized so it had to be cut out. The guy I happened to go to did it all for a great price considering pressing out the bushings was crazy hard and took him all day. To say the least, it was a pain.
Now after about a week, I'm noticing grease around the LBJs. So, I'm thinking those are failing. I wish I had more time to think about it earlier and I would have probably just replaced the entire LCA assembly. But now I'm thinking of just using the Moog LBJ on the OEM LCAs since they're pretty much rebuilt at this point.
What do you guys think? What experience or bad experience have other had with the Moog LBJ replacements?
Take a close up look and see if the boot is torn. My 320k LBJ was super tight and dry so yours may still be tight.
Sent from my SM-G920V using Tapatalk
I just finished up my suspension (Icon stage 1) and went to have the 4R aligned today. I was told they couldn't get aligned because the LCA cam bolts were froze. They quoted me $850 to cut off the factory arms and replace the lower. I declined because I can do this myself if needed. My question is could I cut the cam bolts and just pound them out, then purchase new bolts? I would rather go this route if possible than put on a new after market control arm.
Thanks in advance.
Thanks in advance.
Purchase both new OEM cam bolts, washers, nuts. I tried using a sawzall to cut but it took too long so I switched to a right angle pneumatic die grinder with 4.5" cut off wheel. It cut through everything like butta. Helps to have a second person moving the LCA this way and that.
There will be no pounding due to the bolt frozen to the inner bushing metal sleeve. You'll have to cut both front and rear cam bolts, remove the LCA from the vehicle, stick it on a vise. Then use the Youtube method of removing the bushings with the pieces of cam bolts still stuck to the bushings. Youtube shows the usage of a hyd bottle jack to push out the bushings, along with using a MAPP gas torch to heat up the bushings. After a while, they'll go POP and Bob's your uncle. Take a look at post #47 in this thread.
Don't forget to cuss a LOT on this project. I give you permission.
I posted up lots of pics of frozen bushings in this thread: http://www.toyota-4runner.org/4th-g...upgrade-lca-bushing-swap-bilstein-6112-a.html
These are the things I was trying to avoid, a problem one to another. So I ended up replacing the control arm with beck arnley with balljoint/grease fitting, axles, struts and spring, differential seal.
Sent from my SM-G930T using Tapatalk
I gotta do this at some point this year. I'm sticking with OEM for sure. Will keep an eye out for a decent deal and pick up a set.
A set of OEM what parts? BJs and bushings aren't available unless you buy the loaded LCA from Toyota.
Well I have the passenger side LCA off and this is a PITA. I would like to keep my factory arms so I'm going to see what I can do to get the bushings out now. I think I'm going to go with the bottle jack method and see what happens. Do you have any recommendations on the brand of bushing to purchase? Worst case scenario I have to buy new arms altogether. Trying to expedite this project since we are heading to Moab on the 25th. I gotta get this completed and get it realigned.
So the bottle jack has been a failure. The outside metal sleeve of the bushing stayed in place and the the rubber portion pushed thru. Now I'm really kinda screwed. I think I'm going to order an off brand set of LCA's for now so I can get this truck on the road. I plan on continuing to mess with factory arms as I have time and get them rebuilt should the aftermarket arms take a dump.
You could put install some Energy Suspension Poly Bushings if you haven't damaged the metal part of the bushing too bad.
The metal sleeve stays in when you install them.
It might be a little late for that....:redbrick:
Listen, don't get discouraged my brother. The empty sleeves are easy to remove using a punch/chisel and a hammer. Just hammer them toward the center from the outside in a couple of places, then just hammer them out of their home positions.
I used Moog replacement bushings, FYI.
Crookedcat
