LSD light is on
tnoble
After installing Icon suspension and LR UCA's, took it down to local shop for allignment. After picking it up i noticed that the LSD light is on and will not go off. I did not notice it talking it over to the shop, mind you I was in a hurry and honestly did not even look. Any ideas??
The wire for one or both of your ABS sensors has probably been stretched and broken. This happens a lot when installing a lift.
I remember back in the 70's all sorts of lights came on when LSD was involved. :banana::guitar2::hiding:
I just installed Light Racing UCA's this weekend and a full Icon setup and had my ABS, differential and slip lights on when I was done. I determined that although the sheath of the passenger front ABS looked intact, I could see inside a crack that the ABS wires inside it were ripped near the UCA bolt. I spliced in a new wire section, heat shrinked it, wrapped it in duct tape to make it thicker to survive impacts, and wrapped some of the original rubber sheath around the sensitive points so it doesn't get pinched again. It works good as new.
You can either repair the ABS line or replace it. In hindsight it might have been simpler to replace it, but I'm stubborn.
I'm at the dealer right now for a similar issue after similar work. I'm too lazy to get under there and hunt down a cable like that. I'm going to go out on a limb and guess I have the same problem - then again, I don't have the ABS light on.
charlesz
