So is it a limited slip or and open differential then? An open differential has no ability to spin the drivers side wheel, with or without resistance. Am I wrong? It sounds like a Torsen differential to me where it is a one wheel drive until it slips and then it distributes power to the other wheel.
My truck has the J-shifter T-case or watever its called. I have the shifter, not the button type like the Limiteds have.
Private joke. Ever since I started a thread on that topic a while back, tbst has been dogging me on most every thread. It's so sad, it's funny.
Do what you want. It's your truck.
The newer 3rd gens have an ATRAC system which manipulates the brakes to try and give the other wheel power.
If its an open diff, how can manipulating the brakes transfer power to the other wheel? Its either connected or its open. Either the wheel can spin or it can't. Please explain.
Yes unfortunately "4 wheel drive" is misleading. The best you can get on a stock 3rd gen is 3 wheel drive. That is a locked rear diff and power going to the front open differential.
So is it 100% transfer to the spinning wheel or does the wheel with traction get some but not much.
An open diff allows the power to go to the wheel less traction. If one wheel has traction and the other is spinning, applying the brake to the wheel that is spinning sends the power to the wheel that has traction.
Applying the brakes can and does help to a small degree. The flaw is that the brakes are also the wheels that you want to have traction too. If you could only apply the brakes to the wheels that are spinning, then the power would go the wheels that need the power.
Which is exactly what Trac does...
Watch this video, it's actually really cool and will help you to understand an open diff better..
Around The Corner (1937) How Differential Steering Works - YouTube
What I don't understand is why doesn't it come with a Torsen Diff.? These weren't cheap trucks to buy.
