LT tire pressure for 5th gen Trail
goughy
I am about to swap out my stock Bridgestone Dueler HT P265/70/17s for BFG AllTerrain T/A KO LT265/70/17 6-ply & 3-ply sidewalls.
The Toyota recommended pressure for the Bridgestones is 32psi. The sticky thread "LT tires need more air pressure" suggests about 42psi.
What pressure would you run the BFGs at?
Thanks for any guidance.
Richard
cant speak for this tire specifically, but going from a P rated tire to a LT tire (guessing E rated) I have noticed that around 40-44 has done well for me in a similar tire. likely you should play around a little with the exact pressure until you find something you like, but will probably end up 8-12 psi over the P rated tire spec.
