Lug Nuts for ATX Mojave or Yuma 908B
I've tried searching a couple ways but cant seem to find a diffinant answer. Which black lug nuts would I need?
Yuma 908B link - Black Rock Series 908 Yuma Matte Black Wheels 908B786045 - Mobile SummitRacing.com
Wheelers Offroad Lug Nuts Link - Wheel Accessories from Wheeler's Off-Road
Do I just need the normal (top one on wheelers site) or some conical style (spline drive E/T ultras)?
Under the Yuma wheel specs it tells you....Conical seat - 60 degree which most aftermarket wheels take.
The ones you have on Wheelers site will work and are the right size(12mm x 1.5) but I personally like splined ones like the black ones from Gorilla so it makes it a little bit harder to steal them.Others make splined ones too as my splined ones are not Gorillas but were included in my wheel purchase and have held up fine in 3+ years.
Thanks - maybe I should try reading...so conical splined lugs it is.
This is what I'm using on Black Rock Series 908 Yuma Matte Black Aluminum Wheels 908B786045
Gorilla Small Diameter Black Tuner Lug Nuts Acorn Bulge Tapered Seat
Item# 21138BC
Thread Size = 12mm x 1.50 Thread Pitch
Black Chrome Plated Hardened Steel (matte finish)
Lug Nut Head Style = Small Diameter 6-Groove Tuner
Conical Seat Taper = 60°
Overall Length = 1.36" inches (35mm)
Outside Diameter = 0.80" inches (13/16") (21mm)
Wrench Size Required = 3/4" or 13/16"
1921SD Key
Item# 21138BC
1921SD Key
Does anyone package 24 together?
bluelinepilot
