Maintenance required indication won’t go away!
Lizard333
I have a 2015 SR5. The dash says “maintenance required “ but no light. The screen reminders in the app tab have been reset. Just can’t get it to go away on the dash board idk what else to do??
. Any help would be so appreciated. Thx in advance
You don't need no stinkin' book, try this --
Turn the ignition switch to the On position, but do not start the engine
Set the MILES/TRIP METER to “ODO” or “Trip A” on the little screen, by using odometer button
Turn the ignition “off”
Press and hold the Trip Odometer Reset button, and turn the ignition switch to the “On” position
Continue to hold down the Trip Odometer Reset button until “000000” MILES appears on the display and the maintenance light turns off.
________________________________________________
Thank you so much!! I looked and looked through the manual. I couldn’t find it. I can’t tell you how annoying that was!!!
One thing that makes that light come on is the oil change interval. There are probably other things too.
The maintenance tracking in Entunes is operates independently from the dash cluster. It seems Entunes pulls mileage data to track your maintenance. So you will need to reset both.
I never got an entune message when my maint required light came on. But I don't use entune and have not kept up with the updates so that could be why.
Jhunt
