Mechanical question on my 98 limited HELP
I would forget about the fuel pressure issue to be honest.
Check the other things I listed first. I ran into this exact issue btw, and my Ignitor was failing. Somewhat common on these trucks.
Ok, I went to the local bone yard and got an ignitor of a 02 Toyota tundra (according to Oreilly's it would fit) same ten pin connection, still no spark? NEXT?????
Did you ever end up hooking it up to a code reader to get this info? Im curious to see if the sensor showed up on the reader as bad without the CEL
That was the next thing I mentioned to check in my PM :) glad to hear it worked out! Odd that sensor failed, might double check your crank bolt while you are in there just to be sure it's not loose.
Yep your pm and a Haynes manual is what made me pull them off and ohm them out. Bold is good to go, so I hope this don't become a weekly deal.
TerryNap61
