Minor Suspension Mods (for Winch and Towing)
ade678
Hi Everyone,
I'm writing to ask for suggestions about how to maintain stock suspension height and rake after adding a winch (HWMS with Smittybuilt X20 10k), undercover armor (RCI aluminum package), and rear airbags (Firestone) for towing.
(Note: this is a sort of continuation of a thread on undercover winch mounts and overland suspensions, but I figure the issue is common enough to merit it's own thread).
After making the above modifications (and running the rig off road for a while), I've noticed that, on average, the front end is now lower by 1/2"-5/8" (34" from ground to top of front wheel well moulding is now down to ~33.5"), while the rear is lifted by a full inch (36" to 37" from ground to top of rear wheel well moulding), which is due to airbags inflated at ~5psi for running without towing. As predicted by many of the post members, the stock suspension still performs wonderfully under moderate off-road abuse.
My question: what do you suggest I do to return the rig to its stock height & rake specs as closely as possible? I figure the easiest fix is 1/4 or 1/2" top spacers up front, which should gets me back the 1/2-3/4" I lost...but still, the rake is off since the rear is now still ~1" higher than before. Perhaps also/instead install a set of Bilstein 5100's up front set at .85, but now haven't I lifted the truck 1" all around? Maybe just go top spacers and leave well enough alone for a while?
One final question: Does anyone know if these minor mods all require roughly the same amount of installation work? (with the possible exception of the 1/4" spacers, which don't need longer bolts, so perhaps can they be "slotted" in without removing the top of the shock?) The 1/2" top spacers come with longer bolts, so maybe put in 5100's while I'm in there?
Thoughts? Comments? Ideas?
Many thanks in advance for your ideas and comments!
My suggestion is one of the Bilstein options. 2nd groove on my 1st gen. 6112's put me right about stock once they settled a little.
Edit: With a hidden winch.
6112s
Thanks adrtoy! I've heard good things about the 6112s. Any reason to go with them over the 5100s? Also, you don't think the 2nd setting will be too high?
All I can speak for is the 6112's I bought a year ago. On the second groove after some time they settled to low for my liking. If you ck the magnetic grey thread you'll see some pics I just posted of the same set of 6112' on the third groove with 10,000 miles on them and the same hidden winch set up.
I'm really pleased with them.
Edit: as for why over the 5100's? When I put my 16 4runner back to stock I noticed I liked the ride better from the 6112's. It seemed like more from the springs than the shocks.
Hey Adrtoy!
I clicked on your photos (nice rig!).
I see one significant difference (although please correct me if I'm wrong): You're driving a TRD pro (I'm driving a Trail Edition), which means that your suspension is already a few inches lifted (and TRD tuned), yes?
Do you think the 6112's would do well in a Trail Edition?
Thanks!
Hey Adrtoy!
Thanks!
This is NOT a TRD PRO but a 2017 TRD OFF ROAD which is the same as my previous 16 Trail Edition Premium that I took the 6112's off of.
So yes they did extremely well or I wouldn't have put them back on the new one.
I put a TRD grill on it.
My 16 on the second groove when it was new. Settled a little from here.
20160327_101502%201_zpsztjjafca.jpg~original
Ahh! Got it...Sorry for the confusion! Had you installed any other lift? Also, what tires are you using?
Thanks!
Those were the only after market suspension work I ever did on a Toyota. Tires are 275 70r17 Firestone AT's.
realjeffedup
