misfires cylinders 2,4 and 6
chimi74
This thing is driving me crazy!!!!!!! I have checked the coils they test good. Replaced plugs and wires. Also the fuel filter. Compression is good in all 6 cylinders.i have a 02' 4runner sr5 3.4L. Any suggestions? Thank you in advance.
Re-check your wire routing. 90% chance it's wrong.
When did it start mis-firing? Did it just happen or did it start after you did some work to the truck? I would tend to agree with Tim, most of the time it's a wire routing problem. Common mistake that has been made by many on this forum. Easy fix though.
If it just happened and wasn't the result of something being replaced and a mistake being made, there are quite a few things that could cause that. You said the plugs are good and the compression is good, so:
3 bad injectors
Possible cracked head or head gasket (unlikely since compression #'s were good)
Bad ground somewhere in the wire harness for the injectors on that side
Bad Throttle Position Sensor
Bad Coolant Temperature Sensor
Being that you're getting a code for all 3 and they're on the same side, I'd start with double checking the routing of your spark plug wires. Easy things first and then go from there.
I picked it up after having the rear end rebuilt. It ran great when i got off the freeway the damn thing died on me. And ran really rough. Then i replaced wires and plugs, fuel filter. I have checked and rechecked my wiring orders. 1-4, 3-6, 5-2. Thank you for the link about fuel injectors.
No prob man.... I've been there... took me the better part of a winter to finally fix mine. I changed plugs, wires, 1 coil pack, cleaned my MAF and Throttle Body, ran some Seafoam through the Vacuum lines, and then finally went through the entire process of replacing my injectors 5 times, before I got it running right.
IF you go that route.... make sure you buy brand new injectors, locally. Don't buy online, and especially don't buy from E-bay. Make sure they are brand new... and not refurbished units.
I tried to save some money, and bought a set of 6 on E-bay for the price of one here locally. Figured I'd get ahead, and just replace them all with refurbished ones..... didn't end so well for me!
Yeah that would really upset me if I had to deal with that. I will give it a try. I hope this doesnt take me all winter!!!! Lol. Thank you again
Were you able to figure it out? I'm having the exact same problem too. Just started last week. I would Appreciate any info you have. Thank you
Cylinder 2, 4, 6 Misfire Code - Runs Fine
Hey guys, my check engine light came on out of nowhere and I get cylinder misfire in 2, 4, 6 - but it runs fine. Is there a sensor or something that could be bad that would give me this just on one side? Thanks
