Misfiring? Timing off?
02runner4
02 3.4L v6
about 169,000 miles
I'm not sure what's wrong but it seems to be off timing and it seems to misfire as I cruise.
There is no check engine light. What could be wrong?
Go hook it up to a code reader anyway. If it's got a mis, it SHOULD trip a check engine light. Did this just start randomly or did you just do/have any work done to it?
I think I had the spark plugs replaced at 100,000 miles, and that's about it.
I just had it emissions passed and I assumed no codes. I can have it code pulled at Advance Auto.
I had a spark plug arching off my block for a while and was getting misfire 3, then I took it into the Toyota dealship and it was a rotted spark plug insulator. It is pretty easy to hear for it make kinda a knocking sound.... best of luck!
Could be plugs...I just had a similar experience last year. When you replaced the plugs, did you use the double ground strap plugs?
You mean dual ground elctrode?
Yes. I know it's OEM and it was replaced about 60,000 miles ago or so.
Yeah, my brain isn't functioning too well right now. I'd say tune up...if that isn't the problem, you at least got new plugs in...never a bad thing.
check rock auto for your tune up stuff too. I managed to get my ngk wires for probably about $10 and the cost of plugs is so insignificant that I just bought them at a local store. ngk wires are like $60!
