Mobil Delvac ATF for 3rd Gen
northernT4R
Hi - many people have indicated their preference for Mobil ATF products for use in their 4Runners. Since Mobil offers a variety of synthetic ATF fluids, is there one which is best for a '99 3rd gen? The Manual specifies a Dexron Type III fluid.
These are the variants I've been able to find:
Mobil Delvac Synthetic ATF
Mobil 1 Synthetic ATF
Mobil ATF 3309
Mobil Dexron VI ATF
Mobil Multi-Vehicle ATF
The Delvac is seemingly the most expensive, but also appears to be the one with the highest heavy-duty rating. ATF 3309 seems to be applicable to some Toyota transmissions, and Dexron VI is apparently backward compatible with Dexron III. Confusing.
Thanks!
Mobil ATF 3309
Mobil Dexron VI ATF
Thanks!
I personally use Castrol Transmax Import Multi-vehicle.
Mobil ATF 3309
Mobil Dexron VI ATF
Thanks!
I personally have used the Mobile Dexron VI ATF on my '99 and '00 4runners with no issues. I recommend that you do a drain and refill and its about 4 quarts that comes out when you drain it.
utkrstam
