Mods for improving MPG
Lewis&Clark
Anyone have any mods for improving miles-per-gallon, particularly on a V8 Limited ('08)?
I'm aware of and not at all interested in the HCF removal. Just wondering if there's any other ways to possibly improve the mileage.
Not that 16-20 on a 4,530 lb. offroader is bad at all. But curious what else I can do to improve MPG/reduce my fuel costs (driving 25K miles per year adds up fast!), without compromising any of the utility/capacity of the vehicle.
dt
Well depending on exactly what utility you need, here are a couple things...
Smaller tires, lower stance, remove roof rails, that sort of thing will increase gas mileage.
If you don't already have one, an ODB2 scanner that displays your instant and average per trip mileage can get you into the habit of being easy on the pedals and you can increase your mileage a good 1 or more MPG with conscientious use of the gas pedal.
^ all of the above, plus making sure all the tires have the appropriate air in them. maybe even go as far as going 5 miles or so under the speed limit to conserve as much as possible. maintenance is also key.. ie.. tires rotated/balanced/aligned properly, etc..
Well, I shed the spare tire, tools and backseats for weight and switched to synthetic fluids on everything where possible. Also I use an instant scangauge and it's change my "pedal habits" substantially. The V8 is really "low down" happy with the throttle, so I find that feathering the throttle even from 1/4 to 1/8th throttle (because drive by wire) makes a huge difference in mileage.
My average is 22.8 mpg so far (50/50 city highway), I have an 03' Sport 2WD that weighs around 3900 lbs. If I am pedal happy though, the 17-18 range is very easy to dip into.
Hypermiling I've topped 31 mpg on the freeway and 25 in the city.
You could try building an air dam in the upper or lower grill when driving on the highway in cool weather to prevent the parachute effect of the hood.
Try to spend less time accelerating. For example, don't take a mile to reach 50 mph. Accelerate reasonably briskly to the lowest possible speed where your V8 will consistently hold 5th gear (50 mph on my V6 4spd) and then anticipate braking and coast whenever possible. The biggest killer of gas mileage is unnecessary braking.
Also, try early braking. For example, rather than wait to brake at the last minute and have to slow to a complete stop behind a turning vehicle, slow early and coast up to them. That way you only have to accelerate a little to get back to cruising speed.
Lastly, be grateful as a consumer that the recent US efforts to increase domestic oil production are being countered by Middle Eastern countries in an effort to price the US oil market out of business, leading to a high supply and low demand situation worldwide. :usa:
how come my 06 sport edition v8 weighs 6,001 pound?
i have 16.4 per gallon on the display with 265,70,17 nitto a/t grapplers ,removed HCF filter and thats it!!!
JMHO, but the gains in exhaust normally end up in an initial "hey, this sounds bad ass" evolving to "damn, this is annoying." I've not heard of any real mpg gains in exhaust/intake mods. Saving mpgs really boils down to vehicle weight and tire size.
What are your guys' thoughts on exhaust systems?
On an N/A vehicle, the best gains are typically going to be from the header back, including removing the cats/resonators. Whereas a typical CBE is very minimal gain, if any. I like mine due to the throaty noise it produces but the BUTT dyno. will tell you different. Of course it may be due to stepping on the skinny pedal further and longer...
I feel like its common for members with exhausts to go louder and cause a drop in MPG since everyone loves stepping on the gas and hearing the nice roar. I know that's exactly what happened with me :jump:
To OP:
Also, I feel unless you are getting subpar MPG you should just enjoy your 4Runner. Driving habits will be the main factor in MPG gains and losses at the end of the day.
^^ Agreed. There's really no mods you can do to "increase" your MPG. The best you can hope to do is achieve that maximum potential of your vehicle. That's a simple formula that holds true for all vehicles...
1. Driving Habit
2. Reduce Weight
3. Proper Maintenance (ie. tire pressure, fluids, etc.)
Edit: If you would like to go through the trouble of opening up your diff. and installing some granny gears, I'm sure this will net you a few MPGs.... And also be WAY more trouble than it is worth.
The cheapest mod (and I wouldn't call it a "mod" per say) is bumping up your PSI in your tires a notch. Throw a bit more air in there but do not over inflate to the point that you are opening the door to reduced treadlife due to over inflation. I run 35PSI now but have gone to 38. Don't expect to get much more in the way of MPG's as this is negligble to far as increases go.
However, when I can fill up today @ $2.27/gal at Costco, I really don't focus or care much about my MPG's. I float between 14-17mpg with my V8 SE. I need a rig to get to the ski mountain, pull the boat, haul my gear, etc., so it's a price you have to pay which I do happily.
I remember used trucks and SUV's going for CHEAP CHEAP CHEAP back when gas prices went towards $4.50+ several years ago. That was one good thing about high gas prices...
Look up hyper-mileage techniques. I'm sure most of it won't apply, but you might find some stuff that translates to your 4Runner.
The V8 doesn't seem to be very sensitive to changes in driving habits. My last car would get anywhere between 23-40 mpg, depending on how I drove, the load in/on the car, weather, etc. In my 4runner I seem to get 16-20 no matter what (unless it's extremely cold out).
Here's my Fuelly: 4runner (Toyota 4Runner) | Fuelly
Any mod on its own might not make a measurable difference, but I'm hoping that small gains will add up. There's a nice list at Ecomodder (65+ Vehicle modifications for better fuel economy - EcoModder.com). This guy claims to be getting 28 mpg hwy in his V8... How to get better MPG in a toyota 4runner - Page 2 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Here are some I've considered:
I keep my tires inflated around 37 PSI, and the ride is noticeably harsh but it doesn't improve mileage much (1 mpg at best).
The roof box doesn't seem to have a big effect, maybe -1 mpg. It's quick to remove when I'm not using it.
I would take off the roof rack, or at least the crossbars, if it was easy, but it looks like kind of a hassle. Maybe I'll do it for the summer. Or maybe I can make some more easily removable crossbars? Maybe just modifying the covers to extend the slot all the way back would work.
Next oil change I plan to use 0W20. Totoya recommends 5W20 now, as an alternative to 5W30 for our engines, and 0W20 has the same weight at operating temperature but better viscosity at startup temperatures. I don't know why they don't recommend their own 0W20 in the service bulletin, but it may be because of cost (6.5 quarts of their synthetic isn't cheap) or because theirs is even more optimized for efficiency than off the shelf oil (Mobil 1 is nice and cheap, and it's what I would use anyway if I was using another weight, so no additional cost for me) that has to work in a wide range of vehicles. I don't expect to see much gain, except for short trips. I'll also do synthetic oil in the differentials one of these days.
When I do the timing belt if I do the water pump too, I'll add a block heater. The engine seems to burn extra gas while it's warming up to warm up faster and meet emissions faster. In the winter a block heater should help reduce that, plus it will heat up the interior faster and clear the windows faster if they are frosty. I might install a battery charger wired to the block heater circuit, too, to reduce load on the alternator and extend the battery life. Electricity is generally cheaper/cleaner than gas (though maybe not if gas prices keep falling). It would nice to have the seat heater come on when the car is plugged in, too!
Next time I need wipers I plan on getting beam-style ones. The lower profile should reduce drag a bit, and they won't freeze up as easily in the winter.
I probably won't do any major aero mods because I prefer to keep the stock look. Plus I got this truck to drive off road, so I don't want to do anything to limit its capability. Notable aero problems on the 4th gen are the spoiler, everything underneath, and the huge side mirrors. I'm thinking some skid plates might help with aerodynamics, unless the added weight negates any benefit. An air dam might be better since a smooth underbody is apparently not ideal. In my state, side mirrors are not required as long as you can see out the back. Various mirrors inside the car, or the anytime backup camera mod could be used in addition to the rearview mirror. I like the running boards, but I wonder if removing them would reduce drag a bit?
I plan to add an override switch to keep the A/C from coming on when the defroster is on. It's so dry in Colorado that I hardly ever need it. It's nice to have a few days a year in the summer, and when it's raining and the windows get foggy, but otherwise I rarely need it. Much later down the road (when the truck is at least 15 years old), I might remove the A/C completely, mainly to save weight since it's just another idler pulley when it's not running. It would be interesting to remove the power steering, too, but it sure it nice to have when going off-road.
There's not much I can think of to save weight, and I'd even like to add some sound deadening material.
The V8 seems to be designed for power and torque, not efficiency. Moving a 4runner around at a constant speed uses so little power that it must be running below it's peak efficiency. Typically low RPM/high throttle is good, but if the engine is too big for the vehicle or if the transmission thinks it knows better than you (I suspect we have both problems) then the engine won't be working as efficiently as it could.
It would be nice if we had Variable Cylinder Management (VCM), but I've read nothing but bad things about DIY VCM. It would be nice if the V8 had 2WD mode for efficiency and donuts, but there's probably no easy way to add it. I don't think 2WD mode helps much, but it may be a small gain that helps in combination with other things.
I doubt exhaust mods do much. Whenever I see (hear) a vehicle with loud exhaust, I notice that it isn't accelerating any faster than the cars around it, despite making more noise. (I also notice that a lot of people with lifted trucks have tires that are too bald to ever go off road, and many people with hi-lift jacks attached to their vehicle have no jack points except the trailer hitch.)
