Moog rear coils....Yay or Nay???
Dude, I know you said you don't want a lift, but I've got a set of '99, front and rear, that I'll sell you. That way you'll be even all around.
I put on the raybestos from rock auto, which are probably the same or very similar and I've been happy with them.
I'm in the same boat. I want the height back and maybe even a bit of natural lift and it's been said numerous times that the 99 tall coils (from the highlander edition) give you an inch of a natural lift because it's taller and will fit 3rd gens.
I'm looking around for the best shop and so far this seems one of the only places that sells them https://www.toyotapartsales.com/
Part Numbers:
Rears ( same for both ) 48231-35210
Color Codes:
Rears: Green/Red
If i did this how much all around lift would i end up with? would i have to get different shocks for those springs?
im a noob to 3rd gens if you havnt figured that out. and trust me i have been reading through other related posts to try to figure it out on my own.
you know there was a recall for the saggy rear springs right? toyota will replace them for free if it hasn't been done already.
would i need different shocks to go with them since it is a "lift"?
I would replace the shocks while you have them out man.
If you're sagging as much as you say you are, the shocks are probably shot as well as the springs.
Just go ahead and do the both at the same time. No need to do it all a couple weeks later....
If you have a 2wd, just getting the 4wd springs is 1" taller. If you don't have the '99, the '99 springs one more inch taller. I think the 15" stock wheels may have been 1" shorter too, not sure. Anyway, the 99 coils lifts my 98 2wd to level or a little more. But they're not staying even. One side is a little higher and it is kind of irritating.
Slight lift but
a great set up is OME 906s in back and 99 talls up front. use the same shocks, provide a bit o' rake.
Get Doc's '99 coils and replace the shocks with fresh OEM ones. I have the part number for the shocks if you want to order them yourself, it would be around $80ish, I think, for the two rear shocks.
Moog? NO. cheap.
How smooth is the ride with this setup?....close to stock?
Are you using the OE (tokico or monroe equivalent) rear shocks with the 906s? This sounds like exactly what I'm looking for. A slight lift, with a little rake, and a comfortable ride - as this is my daily driver.
The Monroe Quick-Strut part number for the 97 and 99 model is the same from my research.
Firm ride, I used ranchos, I really like it.
The rides good
i put some miles on this set up and liked it. I used the bilstein HDs all around. i have a 00' so im not sure how much rake you could end up with but mine as around 3/4" i think. I've read good things over on yota about the HDs paired with the 880s up front.
I've been running Moog 81041 rear coils for a year now and they have been fine. I wouldn't spend the money for OEM springs and I wasn't ready to buy all 4 springs and shocks, so these were the best option. They ride just like stock springs should.
My Moog coils are already sagging in the rear after 1 year of use; the Moog fronts are doing just fine. I'm going to get some OME 906's to replace them.
Thanks for the input.
I've been searching and reading posts for months on here as well as Yotatech. I've become 'decision paralyzed' from too much information. I'm literally overloaded. The time has come however, the nice weather is upon us, and I need to make a decision.
The ride now is non-existent...the shocks just froze up. At this point, anything would be an improvement.
I'm going to go with OME 906's w/ Monroe Spectrums for the rear, and Monroe Quick-Strut from O'Reillys for the front. Cost will be about $550 and should provide almost 2" rear lift, with slight rake on my 97 LTD. Larger tires are not in the future.
Any other thoughts or suggestions?
Deno91
