More questions
What springs and shacks are you swapping too? You shouldnt need anything like that, nobody else has needed them
i have xreas with air suspension in the rear. I'm swapping 5100 bilsteins and FJC springs, on all four corners. From what i understand, the rear does not have lower spring retainers stock, therefore you need to weld/attach them to hold the FJC springs in place
IF you remove the air bag suspension I wouldn't mind buying the auto leveling unit off you.. If I could make it work for adding air bag suspension to my T4R for when towing that would be sweet..
Interesting find there, never saw that. I know I looked at the coil clips they sell, and that is the way I've seen this done. I know it lists that welding is required on those you linked to, may be a more solid design.
BillM777
