Morimoto 2Stroke 2.0 LED Low Beam Headlight Install
Tried again. Not adding anti flicker module. $105.60
Sent from my SM-G892A using Tapatalk
Don’t buy from eBay. Go to their website from the link posted above.
Has anyone tried the morimoto high beams. I installed the low beams in my 2013 trail and they look great. Only issue is the white yellow contrast when I use my brights. May have to give them a try.
For the black Friday sales I ordered the 2 Stroke 2.0 for the low beams (H11) off of the Retrofit Source, and then the Xenon Depot 9005 LED kit (with DRL module) for the high beams. They're pretty close in terms of color and both come highly recommended. I would have liked to order 2.0's for the high beams as well, but Morimoto doesn't have a ready-made solution for the dual-use DRL yet. I also ordered the Philips H16 fog replacements in yellow from Xenon. Looking forward to see how everything turns out.
I have the same setup. Works great.
Can I use two sets, one for the low beams and one for the fog lights? Or will the fog light's out drive the low beams in fore ground?
I would avoid fan cooled LEDs for the foglights as the fan will encounter dirt and water. Passive cooled (no fan) LEDs is better for foglights.
Unsure, but the newer ones are supposedly more compact. The "older" ones are supposedly 200% brighter than stock and the new ones are 160% brighter.
Hmmm. I'm thinking of going for the older brighter ones.
Tirerack has them for $115. Cheaper than Amazon or Ebay. But it says X-tremeVision (12794UNIX2) instead of XtremeUltinon (12834UNIX2).
https://www.tirerack.com/lighting/detail.jsp?ID=2630
I'm not sure X-tremeVision (12794UNIX2) and XtremeUltinon (12834UNIX2) are actually the same? They appear to be. :noidea:
supernova v4
Based on reviews on headlight revolution on their 4runner, they think the supernovas fit, are brighter and have a good light pattern.
They have H11, 9005 with canbus to allow DRL, and a yellow 3500k H16 plug and play for fogs. I don't remember specific lux/lumen numbers. they are fan cooled.
They also have a reverse LED bulb of around 1000 lumens? (level 2 kit)
Just curious if anyone has experience with these bulbs?
Thanks.
2001ATL
