Alright my 2 tire morrflate arrived. Here are my initial thoughts:
It uses I/M quick release fittings, not the T style that the rest of my system was built on but I have extra fitting lying around so no issue. Not a positive or negative, just something to consider if you plan your projects properly (the way I don't). Note that before starting on the compressor install at the beginning of this month I was not even aware that there were multiple types of fittings.
With the compressor mounted inside the engine bay, passenger side (MORE ARB mount) I definitely needed the 25' hose I have to have the morrflate reach the back tires. I am unsure if the 15' extension morrflate sells would be long enough. Each "arm" coming off the morrflate manifold is about 8' in length, or long enough (with some wiggle room) but you will NEED an extension if your compressor is not portable.
No leaks detected, but then again all I did was use it to take my tires from 31.5 PSI to 34 PSI.
Like Chilow above said these hoses are made to be flexible and light, heat resistant and tolerant of abuse not so much. I have several 18" braided steel hoses, an air/water separator, and a 1 gallon tank in line before the morrflate connects so I don't predict too many issues on this front for me.
Also arrived today was the hard case (Seahorse 300) that fits under the hood above the fuse box, in which I was hoping to fit both the morrflate and the 25' extension hose. This won't be happening. It'll fit the morrflate no problem, probably even the 4 tire version, but definitely won't fit the 25' 3/8th ID extension hose even without the morrflate. I might be able to squeeze a 25' 1/4 ID hose in with the morrflate, but I haven't bought one to find out yet.
