Mounting Side/Reverse LEDs with stock rack?
Yep...I tucked it in that panel, then ran the wiring up to switch. I used 14ga wire. I don't know if I needed that big, but I had some handy. I have a blue sea fuse block under the hood, so all the relays are under the bracket for the fuse block. The switch is in one of the blanks behind the shifter.
Awesome. I'm definitely going to have to look in to this. I've run a few wires all the way to the front console, so I don't think it will be too hard from back there. Thanks for all of your help and input. I never even thought about simply screwing a light in there!
Not a problem at all! Good luck and post some pics when you're finished!
What about mounting lights in the inside of the tailgate? Sorry I don't have a photo, but I covered the tailgate in probably 12' of led strip lights and wired them into the trunk light switch. I just keep my tailgate open while camping and those lights light up a large section around the back of the truck - enough to cook or do other things around the back of the truck.
CoaterZ_FL
