What He Said. You can also run it to basically empty, add half a tank and note how many gallons you added, set trip odometer to zero and then drive it to basically empty.Then just divide gallons to miles. I did this last week and my MPG average was 21. I never went above 65, used cruise control quite a bit and just took it easy.trd_4runnin said:You won't find any calculator because all vehicles are different. Different engines rev different at different speeds and what not.
You are correct. For every 5 mph you go over 60 mph, it's like you are paying an extra 20 cents for gas.swimminggerman said:I beleive that the standard mpg that is stuck on the window sticker for each and every car is a basis of that vehicle traveling at 55. Above that supposedly you loose more MPG ecspecially over 60 it drops. I just remember reading this through several forums and write ups.
