Mr.yoshimura
Mr.yoshimura
High weird idling after I install the stock intake back in!!
I remove my K&N FIPK today and clean out my TB and install the stock air box back on today cause my lease will be up next month. after I finish I started the 4R up and it was idling very high @ 1500 rpm. then I took it out to drive it for 5 min till the motor warm up to normal temp. when the 4R is in drive it idle at about 700 rpm when i went to put it in park it was idling @ 1,000 rpm at normal temp. usually it idle @ 500 rpm in D before when I had the K& N on at normal temp..
anyone know what the hell is going on here? I put everything back the same way it came out and even double check everything before I started the 4R. do you guys think maybe its the ECU making it idle high like that because i had the k&N on? do you think after I drive it for a while the ECU will adjust itself back to normal? I have an 04 V6 by the way.:confused:
try pulling the negative battery terminal off for about 15 minutes and then reattaching. this should clear out the ECU and let it "relearn"
OK, I drove the 4R 50 mile today and it all back to normal! it was the ECU re justing its self . @ normal temp in D it idle @ 600 rpm and in Park it idle @ about 700 rpm. all is good except I notice a drop of 1.5 mpg in gas miles and the gas pedal don't feel the same any more it does not respond like it use to with the k&N.:D
another way is pulling your EFI chip out from your fuse box. ;):
