Multi Information Panel
Re: Re: Re: Multi Information Panel
4runnerndachi said:
Thanks,
I read the thread.
However, I wonder if there is an easy way to replace the LCD backlight without dismantling the entire dash
Lookhere
Start where it shows the A/C controls.
What do you mean by multi-info panel?
..you said "easy way to replace the LCD backlight without dismantling the entire dash"
If you mean, the aircon/climate control display? because there ar only two displays with LCD...Then, there's a screw in that compartment below the aircon display, once removed, you can pull that climate control. Remember the location of the bulbs from the thread link above...replace.. :)
Crookedcat
