Isaias
Check engine vac and trac light on. I replaced the gas cap about 8 months ago. I have lots of obd codes showing
code c1201p0455 p0456 p0441
The gas cap replacement has fixed the problem before. Now I'm concerned it may be something else. Before I drop another $30on a gas cap I wanted to see what other problems may be happening. I've also tried to wd40 the ring on the gas cap. When this started last week it kicked out some other codes
C1241 c1223 c0215 but those have went away.
So far I've read charcoal canister purge valve gas cap. I'm not exactly sure how to check the valve under the hood. Can I just take it off and blow it it? Does it need to be vacuumed if I put it back? Will happen if I take off the hoses and remove the canister? I don't want to cause damage I'm really tight on money right now and looking to do the replacements if needed by myself. I've read other forums but none really mention multiple codes. Are there vacuum hoses that may have come off? If so I'm having no luck on finding the actual pictures that show me locations for 2007.
Today after work I went to start my car and it didn't start the first time. It sounded like it was gonna start but didn't turn over. I want to say it was related to the issue I'm having cause I've NEVER had a problem like this before
