my 86 resto/buildup
jason in tn
just thought I would start out with some info and pics on my 86 I lost all my early pics so all I have is mid build to now but you will get the idea. the body on my runner was kinda beat rust in the quarters crused lower rear quarters etc so the body work has been a long prosses
060.jpg~original
058.jpg~original
057.jpg~original
024.jpg~original
still working on the body but its getting better, I have also rebuilt the 22re didnt have to do much machine work, I did replace the cam with a LCE rv style cam.
025-1.jpg~original
029-2.jpg~original
033-2.jpg~original
as you can see I have already painted the engine compartment to the new body color. I replaced the clutch with a luk/daikin heavy duty clutch,master and slave. other mods include bolted motor mounts, electric fan.
curently trying to work out a few bugs with the engine it ran but really rich while adjusting a few things now it wont start but Im just going to go back thru things till I figure it out.
next on the list is a v6 brake upgrade I already have most everything I need just waiting on that step. from there will be suspention, 1.5 ball joint spacers, new ball joints and ca bushings, idler arm still trying to decide on the rear suspention.then on to paint and apperance. I have started a few mods in that area
217.jpg~original
217.jpg~original
pickup truck tail gate swap
022-1.jpg~original
020-2.jpg~original
half top started.
well ther it is at this point let me know what you guys think. any ideas or suggetions are welcome.
oh wow!
Im along for the ride :D
haha thanks, with my job its been kind of a slow ride but its getting there. Im home for a few days and really hoping to figure out the not starting issue so I can move on to the front suspention and brakes.
love the half top idea.
thanks the half top is not an original idea of mine I seen a pic of one on another site and loved it, had a spare top that had been abused by its po and decided to give it a shot it needs some stiffening up around the back but I had to cut it to figure out what I would have to do to brace it up.
need some help, I had it running but it was running really rich, in trying to figure that out it has gotten worse to the point it will not start, pulled the codes and got a 6 and 11 one is TPS the other is igniter. so I have changed the coil igniter assembly to a know working unit, changed the AFM to a known working part, checked for spark at plugs checked good, checked for fuel at the return line good stream while cranking, checked TPS checked ok, made sure dizzy was timed correctly. not sure where to go from here. the no start issue came after cleaning the AFM and throttle body. could really use some help, thanks in advance.
got it running its rough but running still not sure what the problem was, bad conection somewhere that for sure will come back to haunt me for sure.
wow its been a long time since Ive updated this sorry, the sad thing is it doesnt look a lot different LOL. Ive been working at it as much as I can but with the adition of my 97 runner i have had to spit my time, along the the purchase of the 97 came a change of plans for this project, I wheel my new runner and am really happy with how it performs so my direction for this one has turned into more of a restoration, I want to make it a nice clean dependable runner that I can dd and just enjoy that way. Im still not driveing but I did getting the running issues sorted out and have been focussing on body work mostly. ok so a few pics.
these pics were took not long after I intalled my b.j. spacers and did the zuk mod Im really happy with how it sits now.
002-9.jpg~original
003-10.jpg~original
004-9.jpg~original
the next few are of the doors getting jamed.
022-2.jpg~original
019-2.jpg~original
2012-06-24_21-18-30_696.jpg~original
then came the underside of the hood.
2012-07-12_19-48-15_108-1.jpg~original
2012-07-12_20-50-08_377.jpg~original
the rest of the body should be coming along a lot quicker now, I decided to go back with the runner tail gate instead of the p/u gate that I had started to use, Im trying to put one together and should have it together soon.
A few other things Ive done, Installed mechanical oil presure and water temp gauges in my sr5 cluster.
011-1.jpg~original
this has been a painfully slow build up to this point but Im really hoping to make some big progress soon I really want to start driveing it and enjoying it rather than just working on it. thanks for checking in.
Did you get the rough running problems sorted out with the engine? If so - what was the cause(s)?
Also - "Slow and steady wins the race!"
Will be watching for more updates.
:cheers:
:cheers:
I did get the running issues figured out. It was a combination of things, problems with the CSI circut as well as a break in the igniter signal wire, were the main issues.
I for sure have the slow part down LOL. its coming along I wish I had more time to devote to it but things are what they are I want it as rite as I can get it and that takes time. thanks for chenking in.
2001ATL
