My Project Toyota 4Runner 2001 3.4 V6
New Silicone Hose Vaccum Red UPGR8
Some pictures of my engine 5VZ faith with their new red silicone hoses
BEFORE:
and AFTER
Some photos of dakar rally in Copiapo, Chile !!
The day Friday I found out that the dakar rally would have a meeting in the dunes of Atacama, so my father went on the 4Runner here are some photos excellent step
New Modifications
Hello, been a while since my last posting, because in my country (Chile) is difficult to get upgrades for my 4Runner, well I want to show my new modifications
-Lift Kit 2.5 "with Driff Drop - Toytec
-Dick Cepek DC-Wheels-Torque 16x8 with 265/70R16 Tires
Next would install any transmission cooler that I can recommend ...
At one time install some more tires Bridgestone Dueler A / T REVO 2 ...
New Lift
PS : is lower than the back as he carried my suitcase on the original tires, the distance between the tire and the mudguard is 21cm front and rear.
Lift After Reinstall footrests
With New Wheels and New Steering Tie Rod End Front 2 Inner & 2 Outer
awesome build, whats really strange is you have a 99-00 grille, black fender flares, which only came till 00, and not on a limited, and also the 96-99 tail lights. i think its an 00 or 99.
New Lift
Che Rivero,muy lindo ver otro Latino en las forums.somos neighbors ahi que soy argentino.la camioneta te quedo muy Linda con el lift y Los rims.cuidate boludo
Vehicle documents are 2001, chances are you have been registered in 2001, perhaps the year of manufacture is 2000 and registered in September 2000 here in Chile, when a vehicle is part of 200 year passed in September be 2001
Thanks !
Thanks !
I was wondering this as well. The grill, side mirrors, and mechanical throttle cable all indicate that this is a 2000 4Runner. I think that Toyota starts building new-year models in August, so this may have been built before September. It's quite interesting. Can you tell us the build date that is on the door sticker?
Check the label on the door and just say TOYOTA MOTOR CORPORATION
Where else can we verify the year of manufacture?
No. They usually put way more information than just that. Look for a sticker like this:
010.jpg~original
The upper right corner of the sticker should say the date unless the sticker is different in your region.
Testing the lift
Some photos of the dunes of Atacama, Chile
with Friend Jeep Wrangler 2.5 4cyl
265 70 16" with 4 psi
Video:
This label is located on the driver's door? because if there is only the Toyota Motor Corporation
I noticed that you have the metal plate on the firewall of the engine bay. North American 4Runner's do not have this so that plate may also have info. You can also check through the VIN number. The 10th position on the vin indicates year.
Vehicle Identification Numbers (VIN codes)/Toyota/VIN Codes - Wikibooks, open books for an open world
Also, your 4Runner sounds good in that video.
delislerebecca
