nevada
Senior Member
that's a dangerous way to think. a bad splash can throw water into the intake. ive seen it done.tire deep water is not enough to kill a motor unless is a sports car. i have had water over the hood on my 4runner(before the snorkel) and in my GX470 a few times with no ill effects. my vote is either a bad ground or connection at a terminal, or a bad battery. you could have caused a short/draw because of the water that drained the battery. if you have a v8 its almost certanly not the start as that site on top on the block under the intake plenum and so getting water into that would almost be impossible.
on a Toyota truck even. 3.0. lifted on 33's. he went through a very small mud puddle. not even up to the wheel, but still ended up sucking water into the cylinder. it wouldn't crank over, he said it had been having issues, it was a bad starter. so we pushed it. he popped the clutch, and a rod made a little extra room outside the block...
