jgarcia said:
Capt Jack said:Great....can you explain how to do the override?
Even Steven said:The only way to do it is to make a navigation disk with the newer version mapping software, but the older version operating software on the same disk. Otherwise, once you upgrade, you'll lose the ability to override the motion lockout.
Do a search on this forum and you'll find plenty of specific information on this.
This will no longer work with newest update. Only solution at this point is to burn the hybrid DL disc.jgarcia said:goto to the screen where DVD is written on the top right.
while on that screen touch the top left, then bottom left, then top left, then bottom left, then bottom right. you should then go into the override screen. press and hold down override button for about 3 seconds. Let me know if it works.
jgarcia said:I'm still able to override my nav even after updating from ver. 3.1 to 7.1
SConnors said:If you load the version (5.1?) disk with the bypass on it, you can remove the disk and replace it with the latest disk to get updated data. The firmware only loads when the Nav looses power...
This must be repeated every time you loose power.
Sean
On the nav screen, touch the dvd button on the top right hand corner. You will then go to the screen that shows what version you have. now touch the top left corner, then bottom left corner, then top left corner, then bottom left corner, and lastly bottom right corner. you will then be in the overide screen. Hold down the override button for about 5 seconds. Done.Capt Jack said:Please advise how you are getting the override to work.
Thanks.
jgarcia said:On the nav screen, touch the dvd button on the top right hand corner. You will then go to the screen that shows what version you have. now touch the top left corner, then bottom left corner, then top left corner, then bottom left corner, and lastly bottom right corner. you will then be in the overide screen. Hold down the override button for about 5 seconds. Done.
jgarcia said:may need to keep it pressed for more then 5 seconds. If not then I'm not sure how to. My nav is gen 3 with ver. 7.1. I have a 2004 limited
kev said:Does this have to be done every time you start the truck??
