Need a quick answer :)
MeBe4running
So cruising down the highway after work and noticed my tail lights where not lit. Turns out nothing will light up on the rear of the truck, apart from when braking. The fog lights at the front won't light either. So my guess is a fuse? Just not sure which one? Anyone help? Cheers
Well got it. Back up lights where blown. Tail and fogs are under the same fuse and it was blown! The only lights I didn't get was the DRL? Anyone know?
This is so weird...... We've had a Ton of rain 23" above average so maybe there's some water somewhere where it shouldn't be. The only other crazy thought is that's the Ac under some of these temperate conditions I've been in that the foot vent under the steering wheel has been dripping water (moisture) and somehow made its way down a wire to the fuse panel. Perhaps humidity alone, who knows.
Thanks for the Fast response! It's always reassuring to known fellow like minded cyber friends are a post reply away! :)
Oh yeah, so are you saying that your DRL still does not work? If so, do the turn signals work properly? I've read that the bulbs in the front have a bad habit of coming loose or corroding, I wonder if some of that rain go into the socket and is causing this?
I haven't had electrical problems since I stopped driving Volkswagons.
Do they still wire the dashboard lights in the same circuit as the taillights so you'll know when your taillights go out?
