Need advice on 2.5 Daystar level Kit,
mybenje
I am planning to purchase the 2.5 Daystar, for my 04 SE, for the front only, my question Do i need to raise the back as well, it looks high enough, did anyone do this just the 2.5 in the front? I am curious how it would look like,
Thanks,
If you want a front only daystar lift, I would do the Daystar 2 inch leveling lift. That will put your 4runner visually perfectly level. The 2.5 lift will give you closer to 3 inches front lift which will be either exactly level or slightly nose high. I had the 2inch front lift for 2 years and it looked good. I put the 2.5 inch lift(front and rear) on recently and I would not leave the front half on without installing the rear (which is 1.5in).
either do the front and rear with the 2.5inch lift (I would then recommend you put larger tires on) or install the front only 2inch lift which you can get for around $50. You can see pictures of the lifts by clicking the link in my signature.
Thanks Pirate IV that helps a lot, your 4 Runner looks great, how did you install the leather, was it easy? Did your rig come with Navigation or did you install it later,
Thanks,
Ambrose67
