Need advice on an upcoming truck purchase
Disciple Andrew
I have started to look into buying a truck and I have decided that I want a first gen Toyota 4Runner but I wanted some advice on things such as what year is the best and what problems certain years had, as well as some advice on certain deals that I find on craigslist and maybe yall can give me some feedback on whether or not it`s a good deal and what price I should go for. Any amount of help would be greatly appreciated. I live in the Houston area and I am hoping I can find one here.
Do a search for the years of 4runners, it has been covered numerous times. As for deals you find, post up links and we will be more than happy to steer you in the right direction.
85 the best year for off roading because of the straight axle. And all the other years are pretty compatible to each other. 88+ came with the 3.0l v6 which has head gasket issues.
if you can afford too, buy one that has most of the mods you want. all the extras will add up very quickly & leave you broke. As an example: I see rigs all the time where someone spent 10K or more building there dream rig. Then after all the time & $$$ run into financial issues or have a baby & have to sell it. They usualy end up getting 50 to 75% of what they spent building it. No mader the price range it always holds true. You never get back what you put into them. (well at least 90% of the time)
Also try to find one with a recent motor rebuild. (unless you can do it your self & know you can do it right.) If it needs rebuilt its going to cost you more than you think. There is always some unforeseen expense: a part you didnt think you would need, an upgrade, something that brakes, or what ever.
I have almost $4000 my 3.0 motor rebuild. I didnt plan on spending that much! But as it came apart the plugs stripped out of the head, several exhaust studs broke off, bolts & nuts stripped, most hoses were so old & brittle that they broke or cracked, clutch was almost worn out, Flywheel needed resurfaced (bought a new one as it was $30 more & the old one was close to not being able to resurface), Had to have the radiator cleaned out, Needed tuns of cleaner to get everything clean before reinstall, etc, etc, etc.......
If i were to sell the rig, Id never get that $$$$ back. But thats OK, as I intend to keep it for many years!)
First decide how far your wrenching skills will take you ! If its basic skills with a will to learn more then look at the more beat up trucks. If body work is your thing then most first gens in our area are right up your alley. By no means are any of the first gens powerfull trucks and automatic trannys being the worst.
I am in Houston to and see all manner of trucks, I try to stay away from all beach rigs ! For me the best rig to look for is an 88-89 3.0 manual tranny trucks,although I am not afraid of the auto and know how to make it perform. It can be a money pit fixing someone else's band aid fixes, plus if you decide to keep it long term it offers a perfect platform for a 3.4 swap.
Good luck with search ! Post up what you find lots of guys on here with good info and resources to steer you in right direction .
For off roading, 1985 22re, 5 speed. If not I'd still stick with the 4cyl. Some really like the corner windows that pull air in, only on certain years, maybe someone can tell him which years.
People like the 85 because it has the solid front axle but also has a fuel injector. Only year with both.
The corner windows were an extra cost option on any year.
Looks okay , check it over real good. Engine is real clean, I would expect dust. Also lots of hidden issues with front axle,do a road test for steering and braking issues .
utkrstam
