Need advice on lift spring choices
seems like the truck has settled after about 1500 miles and now it looks like it needs a lift. I am set on doing 5100's just need to decide on springs
ended up going with OME springs! 2883 Front and 2895E rear which should give an all around 2" lift. Got Bilstein 5100s. I bought new tophats and got the front assembled on the shocks.
I just want to make sure before install(as I forgot to look), but are the front springs even height? or is one higher than the other? I read that the older OME springs had different heights, but not sure about these current models.
IF anyone knows I would appreciate it. I was hoping to get these installed this week, but it seems my 3 ton harbor freight aluminum car jackstands are too short so I am waiting for some to come from Amazon.
hey JDM,
How are you liking your suspension set-up so far with billies comboed with OME? Do you think you should have used the billies with stock springs and set the front at .85 for a slight lift to level out a bit? or should you have gone with Dobinson springs instead of OME?
hey JDM,
It rides ok. I am happy with it for the cost, but if I could go back I would honestly have gotten kings. The OME/bilstein combo is good, especially for on road use and slow crawling. But on fire roads/high speed roads made of 1-2" rocks I find that they stiffen up and I get some wheel hop because they are unable to absorb bumps quickly.
So my conclusion would be: Are they good? Yes the work great. For my specific use, not the best option though.
Eventually I will probably upgrade. I actually like them fine for now, so at this point it is at the bottom of my priority list to upgrade until I get everything else done.
Cant argue with cost benifits of the more practical set-up. As much as I would like to get Kings, I dont use my T4R as much off road as I would like to benifit from a serious set-up like Kings. Billies and OME/Dobinson would be adequate for my purpose.
I do think it is a practical setup and honestly works well. I don't really daily my 4runner so it is primarily used for offroad/camping/fishing/hunting, so I think for me it is more noticeable since most of my driving with it is offroad. I think its a good middle ground to hold me over for now until I decide on better upgrades.
AndiGarage
