Need Guidance: Differential Fluid Type
DaveK22
I tried a search but couldn't find answer.
I need to bring my 04 SR5 (107k miles) to my local mehanic for a repair. Since I have it in, I was thinking about having differntial fluids changed...as pretty sure previous owner never did.
Is it critical to have to use Toyota fluid? If not, can someone recommend a good alternative that would be readily available for a local garage?
Thanks in advance.
There are a hundred threads on this, but the bottom line is with the gear sets you do not have to use Toyota fluid. You also do not have to use over-priced "name brand" synthetic fluid. Gear sets are very very happy with regular "dino" oil in the differentials. I learned the hard way that the $3/quart stuff at Walmart works better than the $20/quart "name brand" stuff at the auto parts store.
The thing you DO need to do is use the proper viscosity. And that info is in the owners manual.
I use nothing but Amsoil in my rig and use their gear oil for the differentials. Dino oil works good also, byt living in MN i notice a difference when it gets cold out, it is smoother and rolls easier.
Great advice. Think I'll do just that.
charlesz
