Need help diagnosing Error Codes
Ser1clymb
I have a 2001 4runner 2WD with 190,000 miles and it has been running like a champ until lately I have been having some error codes pop up and need help diagnosing the cause.
Earlier this year in June I did some maintenance work for stuff that hadn't been done (plugs, wires, DS 02 sesor, pads, air intake hose, fuel filter, cleaned Throttle body, PCV valve with hose and grommet, etc) and then I moved from Alabama to Idaho which was a lot of driving with no problems. But in the last month or so I have been having these codes come on and can't figure it out. I am not the most mechanically inclined so please bear with me, but any input will be greatly appreciated.
The codes are: C1201, C1223, C1224, C1253, and P0420.
Post the descriptions for the C codes. Those are chassis codes
P0420 means you need a cat on bank 1
I have checked the descriptions, but don't know the best way to diagnose the cause. I know the C2101 is default when the CEL comes on.
C2123 is ABS control system malfunction
C1224 indicates the NE Signal Circuit
C1253 indicates the motor relay circuit
Is there a way to distinguish between the cat and the 02 sensor other than changing the 02 sensor and seeing if it goes away?
tssawlson538
