TNRunner99
I just recently installed an OME 2.5" lift. The quality of the lift is great but I'm not too happy with the ride, got about 500 miles on it now. I'm only driving on the road right now and the OME setup is too stiff and jarring over bumps. I have the 883 coils on the front and 890s on the rear with OME comfort shocks.
I am looking to do a mod of the Tundra TRD and FJ80 spring set up all on Bilstein shocks. (Heard this is a much better ride.) First question is can you use the 883 front coils with the 5100 height adjustable shocks. I want to get 3" of lift all around on this lift, I have an ARB bull bar plus a budbuilt front skid and think I may need the extra strength coil over the TRD Tundra coil. Not sure about weight differences since the Tundra coil was designed for a V8, though. The front "stiffness" isn't bad and I think a Bilstein shock would help. My driver's side is still about a 1/4 of an inch lower and the adjustable shocks would help solve this problem. How hard is it to adjust the shock?
On the rear I only want 3" of lift and don't tow any loads or heavy gear. Want to go with the Bilstein 5100s here but not sure which spring to use. On a lift info post it shows these coils;
19" Double Pink Light Blue White 7.5 wraps
18.5" Double Pink Grey White 7.5 wraps
18 7/8" Orange Orange White 7.75 wraps
It said 7 wraps should give 3-3.5" of lift. Any clue on which ones would be the best for just 3"?
I'm also wanting to see if anyone has part numbers for these coils and shocks as I want to get the coils from Toyota. Any help would be greatly appreciated.
I want to get together part numbers for springs and shocks for others that are looking to lift using this setup.
