Antman
Elite Member
I need some help here...
I'm installing a new driver's side hub/bearing assembly. I thought everything was ok, went for a test drive and the brake disc is rubbing on the heatshield on hard right turns.
So- I get under the truck and notice a gap between the end of the CV joint where it meets up to the spindle. (see pic- it's the black greasy line).
Now, I took it all apart again. I can eliminate the gap when the hub is off. When I start to tighten the 4 bolts that hold the hub on it opens the gap back up again. I tried pulling the axle tight with the castle nut to eliminate the gap, but as soon as the 4 hub bolts are tightened it opens the gap again.
Simple repair taking me all damn day, and now I'm gonna need a ride to work tmrw. Damn!
Any ideas?? [MENTION=66389]BlackWorksInc[/MENTION] [MENTION=6387]scott@Hightec[/MENTION]
