Need help identifying plugs in engine bay again
Power antenna plug.
Did you find the home for the 4-pin plug? (if not, wire colors again!)
-Charlie
Aw crap. Was hoping it ABS. I did find it, it was hiding under the air filter housing. Plugged it in but I don’t see any change at all. I guess I could
See if I didn’t plug it in all the way. I should have taken out the filter and made sure.
Thanks for all the help Charlie
So i took the airbox out and it wasn't plugged in all the way, and it wasn't in all the way, but once i plugged it in it didn't change anything. There were 4 wires, white, light green, pink, and I don't remember but i think it was black and white or black and yellow.
Didn't you say your camshaft sensor CEL went away after you plugged that in? Sounds like your good with that plug. What codes are you getting now? I've read the entire thread and it said you are getting some cylinder misfire codes? Reset the codes and try it again after fully seating the 4-pin plug and report on what codes you have then.
I tested both of my front ABS sensors with my multimeter and they both stayed at about 1650 which is good ive read. Couldn't check the back i was having trouble getting the wires down. I have a feeling it is something to do with that one plug but i can't find anything on it anywhere.
I'll offer again, a pizza to whoever cross references and helps me fix my issue. I'll throw in breadsticks too. I'm desperate here
If your talking about the plugs on the upper shock towers, yes they are a pain to get to. Both rear ABS sensors plug into a "Y" harness that goes into the cab which can be accessed under the rear driver's side seat under the carpet where the gas tank access cover is. I'm not sure which wires it is. Shouldn't be too hard to figure out though. I'm sure someone has a pinout here that could chime in.
Alright I’ll get to that in a hour or so. I guess I figured the camshaft plug was fully seated. It kept switching what codes I had. Misfire in cylinders 4/6, then just 6. Then 5/6
I’ll look for those plugs
Jhunt
