NEED Help PLEASE!!!!!!
lensp4
Hi,
New to 4runners just got 2000 4runner sr5.here's my problem just installed
the passenger front speaker works but now my power window doesn't work.
All I did was cut the yellow and grey wires at the speaker and hook the new one up.
Thanks,
Len
did that tried to use the driver side to roll down that didn't work.is there a relay or a fuse t could have blown.
I am sure there is a fuse either under the dash or under the hood. If you have a volt meter check the switch connection for power. If no power then find the fuse.
Hopefully the key is on (sorry, I had to ask)
yes the key was on went ahead and did the driver side . hooked it all up and i'll be damned everything is working again.Thanks for trying to help
Len
seltzernator
